Question- if this H64 Thermador Range Hood has a remote external blower on the roof, there is not an internal blower in the actual hood as well correct? Just moving in to house and we are not sure what parts are missing inside the hood and control panel if any. Everything worked until recently and then fan/blower stopped working. Took off filter and all we see is control panel with lights. handyman found external blower on roof. Thank you!
Groups: APP Team
Hi. If the hood was working ,than what missing parts you are referring to? To check why the blower motor not running you have to measure if there is 120VAC to the motor. If it is - replace the motor. If not - check the solid state blower switch.
Thank you. Post the results.
Simon.
