Rob 2
#1 Posted : Monday, April 16, 2012 8:40:53 AM(UTC)
Rob 2
Washing machine will not agitate or agitates very slowly, but otherwise functions correctly. checked belts and pulleys appear to be fine any suggestions, appears that motor only runs in one direction.
Simon / APP Team
#2 Posted : Monday, April 16, 2012 10:05:25 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Using the potty knife release two clips and remove the front panel.
See if the motor and transmission pulley turns normally, the belt is not sleeping.
If that checks OK, loosen up the 1/4" hex set screw and remove the agitator.
Start the wash cycle .
If the transmission shaft is slow - you've got the bad transmission.
The transmission kit Part number: 6-2097750
Here are the breakdown diagrams and Replacement parts for Maytag LAT9206BAE WASHER-TOP LOADING | AppliancePartsPros.com
Thank you. Post the results.
Simon.
