I need help in replacing the door hinges on a Jenn-Air oven door model #JJW9830DDP. I received the hinges attached them to the door, and did this by looking at the way I took off the old hinges and put the new one's on the same way, attached the door to the oven by putting the hinge on then locking it down and when I put the door up both hinges popped. Is there something that I should of done or could you please tell or direct me on how to properly replace these hinges.:)
