woodsdog
#1 Posted : Thursday, April 12, 2012 2:56:18 PM(UTC)
woodsdog
I'm having draining problems with my GE. I've already read a lot, and tried many things mentioned here, but I'm still not sure what it is.
Right now the dishwasher has been removed, and I've started inspecting different parts. Some of the things I have done:
* checked the sump area. It's all clean.
* checked the drain valves and tubes, all clean.
* took off the drain pump asm (part 325). I have hooked it up to a 120 and it makes noise. I'm not sure if it's doing anything, but it's making noise.
This machine is about 1.5 years old. What else could I check or look at?
Thanks for any help.
Simon / APP Team
#2 Posted : Thursday, April 12, 2012 3:20:16 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
First of all you need to check the air-gap for any restrictions.
Open it and check central tube (top and bottom).
If everything is clear then see if the impeller turns when the drain pump is working.
If not - replace the drain pump.
The drain pump Part number: AP4540842
Here are the breakdown diagrams and Replacement parts for General Electric PDWT480R10SS DISHWASHER | AppliancePartsPros.com
Good luck. Post the results.
Simon.
woodsdog
#3 Posted : Thursday, April 12, 2012 3:22:05 PM(UTC)
woodsdog
I don't have an air gap. my drain tube goes right from the dishwasher to the disposal.
I don't notice anything turning in the pump. this might be because the impeller is hidden or it's not turning.
Simon / APP Team
#4 Posted : Friday, April 13, 2012 10:55:58 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If you have a 120v to the drain pump and impeller doesn't turn -replace the pump.
The drain hose before it's entering the disposer must have the air loop positioned higher then the disposer inlet.
Check the disposer inlet for clogs.
Good luck.
Simon.
woodsdog
#5 Posted : Saturday, April 14, 2012 6:11:37 AM(UTC)
woodsdog
I figured out the problem. There was something stuck in the drain pump, preventing it from turning. I had to take out the three hex head screws to clear it out.
Thanks for the suggestions. Very Cool!
Simon / APP Team
#6 Posted : Saturday, April 14, 2012 2:24:47 PM(UTC)
Simon / APP Team
Groups: APP Team
You are very welcome.
Simon.
