After going thru the wash cycle with appx. 15 minutes left - the machine will through up the SUD and F2 code. I can turn it off and then change to spin/drain and it will pump out the water. I use only HE detergents.
We have the F2 problem also. We are ordering a new drain pump. Does anyone know if we should replace any other parts when we replace the pump, i.e. o-rings, grommets, etc.?
Thanks.
