newelldj2
#1 Posted : Monday, April 9, 2012 12:40:32 PM(UTC)
newelldj2
Our disposer is leaking through the cover plate for the ground connection at the bottom of the disposal. There is a small stream of water when water is put down the drain. After the water from the tap is turned off it reduces to slow drips. The leak is not coming from the upper housing, around the housing. Any Ideas?
newelldj2
#2 Posted : Monday, April 9, 2012 12:42:08 PM(UTC)
newelldj2
I appreciate any help
Simon / APP Team
#3 Posted : Monday, April 9, 2012 4:48:46 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Replace the disposer.
Simon.
Struhln
#4 Posted : Monday, April 30, 2012 2:51:02 AM(UTC)
Struhln
There is a button on the very bottom. If that doesn't work, try Drain-o. Then, if that doesn't work--call Roto Rooter or a plumber.
Pro Cleanse
newelldj2
#5 Posted : Monday, April 30, 2012 9:23:42 AM(UTC)
newelldj2
Thank you for all the help. I replaced the disposal.
Newell
Simon / APP Team
#6 Posted : Monday, April 30, 2012 11:38:43 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
jacobwilson8
#7 Posted : Monday, June 17, 2013 9:32:36 PM(UTC)
jacobwilson8
Can’t there be a solution except changing the disposer.
Guest
#8 Posted : Wednesday, February 23, 2022 4:09:36 PM(UTC)
Guest
Groups: Guests
leaking garbage disposal (Garbage Disposer Repair)
by gesche444 8/11/2014 3:23:39 PM(UTC)
