Maytag performa dryer. I have cleaned all the ducts, the fan, replaced the thermal fuse, replaced the felt pads the drum rides on, vacuumed the inside where the motor is. And the breaker at the breaker panel still trips.
When this happens the first thing I recommend is to replace the breaker. This may fix it and it will rule out a faulty breaker as the problem.
