langa1975
#1 Posted : Friday, August 28, 2009 6:01:40 AM(UTC)
langa1975
My GE dishwasher works fine except it does not drain water out. No leaks. Is it the control panel / switch or maybe a check valve? Any help would be appreciated. Thanks
Frank / APP Team
#2 Posted : Friday, August 28, 2009 7:19:06 AM(UTC)
Frank / APP Team
Your unit has a drain solenoid attached to the pump, do you know whether it's activating or not? It will usually make a "clunk" sound when it does. If it's doing that, you may want to make sure there isn't an obstruction in the outlet where the drain hose attaches.
You didn't just install a new garbage disposer did you? Below is a picture of the solenoid.
Part number: AP2039738
langa1975
#3 Posted : Friday, August 28, 2009 7:52:02 AM(UTC)
langa1975
Thanks Frank, I will check the solenoid. It isn't making any sound when it is supposed to kick in and start draining.
Ge dishwasher will not drain (Dishwasher Repair)
by Handyman924 2/24/2017 8:05:27 PM(UTC)
GE Dishwasher will not drain (Dishwasher Repair)
by npcharlotte 6/20/2009 8:04:32 AM(UTC)
2 year old GE Dishwasher Will Not Drain. (Dishwasher Repair)
by gmguy01 3/21/2009 9:20:48 PM(UTC)
