Following a "power spike" to our neighborhood, our breaker box surge protector seemingly protected all electriacal applicances in our house. However, when resetting the breakers, or at someprevious time, the control panel on our Whirlpool 465 Super Capacity Accubake range ceased functioning. The display reads "88.88" with a subletter and nothing connected with the display works. I have disconnected the power to the oven, waited 30 minutese to an hour and repowered but nothing changes. The cook top works fine but the oven does nothing.
Is there something to diagnose or should I replace the control board?
Thanks in advance
:) :( :confused: :mad: :p ;) :D :rolleyes: :cool: :eek: Originally Posted by: anacaparob ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Following a "power spike" to our neighborhood, our breaker box surge protector seemingly protected all electriacal applicances in our house. However, when resetting the breakers, or at someprevious time, the control panel on our Whirlpool 465 Super Capacity Accubake range ceased functioning. The display reads "88.88" with a subletter and nothing connected with the display works. I have disconnected the power to the oven, waited 30 minutese to an hour and repowered but nothing changes. The cook top works fine but the oven does nothing.
Thanks in advance
any response when buttons on the keypad is pressed
No-control panel buttons don't do anything
on the tag on the range what is the digit after the "q"
5 is the only number following the "q"
Thanks and still hopeful
reading some specs now.. seems as if, more than likely, it will be an ERC...
