rlarson
#1 Posted : Wednesday, March 28, 2012 11:31:27 PM(UTC)
rlarson
Hello all. I am have a bad sound on a normal cycle at like 45 minutes. Its like a loud grinding sound. i have take it apart as far as the chopper assembly. and cleaned out some gunk that was in there also. I happen usually at the 45 mark when i think it does a big drain of the water. cause when you start it like around 70 or so it does a drain there. it doesn't do that noise at that time. But at 45 minutes its making that loud grinding sound. Should i replace the drain motor or is there any other test i can do to fix this. Thanks.
ApplianceJunk
#2 Posted : Thursday, March 29, 2012 4:18:20 AM(UTC)
ApplianceJunk
Hi,
When it's making the noise I would unplug the wire harness that goes to the drain motor to see if the noise stops.
If the noise stops then you know it's the drain pump making the noise.
I replace a lot of these little drain pumps because they get noisy.
Kenmore Elite Dishwasher Problem (Dishwasher Repair)
by AndyH01 3/31/2022 3:33:31 AM(UTC)
No power to control panel Kenmore Elite dishwasher model 665.12793k311 (Garbage Disposer Repair)
by John Boof 2/2/2022 6:56:51 PM(UTC)
Kenmore Elite Dishwasher Tech Sheet needed (Dishwasher Repair)
by Recon2it 3/15/2019 3:06:42 PM(UTC)
Kenmore Elite dishwasher 665.13112K700 blows thermal fuse (Dishwasher Repair)
by rrsteven 10/31/2018 9:02:16 PM(UTC)
Kenmore Elite Dishwasher 665.16039403 Wash & Pump Problems (Dishwasher Repair)
by Maico18 7/24/2018 10:35:33 AM(UTC)
Kenmore Elite dishwasher (Dishwasher Repair)
by drewster 11/1/2016 4:26:55 PM(UTC)
Kenmore Elite Dishwasher diverter installation (Dishwasher Repair)
by fasta6 11/13/2014 6:26:52 AM(UTC)
Kenmore elite dishwasher (Dishwasher Repair)
by lwarden 2/11/2014 8:31:48 AM(UTC)
Kenmore Elite Dishwasher wont start (Dishwasher Repair)
by jlewis2407 9/22/2013 3:54:19 PM(UTC)
Kenmore Elite Dishwasher - stuck - green light flashing (Dishwasher Repair)
by jfwilliams3 4/28/2013 7:52:01 PM(UTC)
Kenmore Elite Dishwasher blowing fuses (Dishwasher Repair)
by dennis728 2/26/2013 2:20:25 PM(UTC)
kenmore elite dishwasher (Dishwasher Repair)
by beaumart@plateautel.net 1/1/2013 2:40:43 PM(UTC)
Kenmore Elite Dishwasher Stopped Mid-Cycle (Washer Repair)
by regpum 11/13/2012 6:34:23 PM(UTC)
Kenmore Elite Dishwasher (Dishwasher Repair)
by Moe147 3/7/2012 8:59:58 AM(UTC)
Kenmore Elite Dishwasher Won't Start (Dishwasher Repair)
by sstanley 2/18/2012 10:38:58 PM(UTC)
