fetgirlygirl
#1 Posted : Sunday, August 16, 2009 2:16:06 PM(UTC)
fetgirlygirl
My wash machine will fill with water and the water will not shut off some of the time. It cycles as normal but the water is not shutting off therefore it overflows. I have already replaced the water level sensor.
sidfink43
#2 Posted : Monday, August 17, 2009 3:52:04 PM(UTC)
sidfink43
See if the water will shut after filling starts if you stop the machine. If so, clean out the plastic tube going from the water level switch to the tub and make sure it is connected good to the water level pressure switch.
If not, replace the water valves.
That should do it, post back with with any problems.
Good luck.
fetgirlygirl
#3 Posted : Monday, August 17, 2009 5:58:20 PM(UTC)
fetgirlygirl
Thanks Sidfink43. I will do that.
Guest (5)
