Range shows error code F13, nothing works. Turned off circuit breaker and then turned it back on and range works for awhile but will again display same error code and has to be reset. I cannot find anything on error code F13. Any ideas? Thanks
George, The F13 error code indicates an issue in the ERC/Control, "F13 = Bad EEPROM Identification/Checksum error. > . (F11, 12 & 13) Disconnect power, wait 30 seconds and reapply power. If fault returns upon power-up, replace EOC." Part number: AP3874704
Thanks and Good Luck
I had a hunch that was the problem. Thanks for the confirmation. George
Originally Posted by: George Karschney ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I had a hunch that was the problem. Thanks for the confirmation. George George, You're welcome, it's our pleasure to assist you. Drop us a line anytime. Good Luck, and Thanks
