everything on the mircoweave works. the vent works the lights work the carasul works. timers work to my knowledge everything works except it won't heat up. i checked the fuse it is OK:mad:
[FONT='Times New Roman'] More than likely the magnetron tube is bad. On this model they go bad very often. It is hard to definitively diagnose a magnetron but if you are comfortable using a volt/ohmmeter we can help you be sure the magnetron tube is bad. If you want to try to replace it this page may help GE Spacemaker Microwave Magnetron Tube Replacement[/FONT]
