hot surface indicator light will not turn off
Originally Posted by: louiers ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) hot surface indicator light will not turn off I'm assuming the top is cooling off. That is usually caused by the limit switch, which is part of the burner on this model. Below is a picture of a 8" burner, the white device with the rod coming out of it, is the switch I'm referring too. Just using this as a example, I don't know which burner on your range is causing the problem. Part number: AP2123826
