Originally Posted by: tb69396 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thanks for the help. I replaced the electronic control assembly today and it did not fix the problem. The only button that works is cancel which cycles for 2 minutes. Any other ideas?
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Moist likely the problem is a bad control panel but there is a small chance for the control board to be bad as well. I would replace the control panel first, hoping it would solve the problem. If you need the correct part number for the control panel then post the color of it. Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GU1500XTLB3 | AppliancePartsPros.comGene. There are two parts in question and what was good for tb69396s dishwasher does not mean a solution for everybody. Unfortunately there is no way to tell exactly which part is wrong in each case.
What is the part number for a black control panel for GU1500XTLB3?
I find it amazing that the exact same problem has two different parts to fix it. Why can't appliance manufacturers quit making junk? A very few pennys spent on making circuits that are not cheap and these things would last a long time. unfortunately it is in their best interest to have us buy a new one when the warranty runs out.
Originally Posted by: Gene Gene - I installed the control panel today and everything works now except the delay start button. This is used to delay the start of the cycle for 4 hours, etc. Any thoughts on how to correct this minor issue?
Originally Posted by: bermanbj ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Gene - I installed the control panel today and everything works now except the delay start button. This is used to delay the start of the cycle for 4 hours, etc. Any thoughts on how to correct this minor issue? Sorry for the delay. Open the control panel and verify the control panel ribbon cable connection to the control board. If there is nothing wrong then the control panel or the control board might be defective. Gene.
Yes. More quality parts. Good luck.
My dishwasher did the same thing again. Then the next day the cancel button quit working, too. I now have absolutely nothing working.
Originally Posted by: tb69396 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) My dishwasher did the same thing again. Then the next day the cancel button quit working, too. I now have absolutely nothing working. If you have not returned the control panel yet then try to install it. Gene.
