Do-right
#1 Posted : Friday, January 11, 2008 8:50:35 AM(UTC)
Do-right
My Admiral dryer has no power (light or Timer) I have checked the breakers and they are ok. Replaced the High temp and Power Thermal fuse ablut a year ago. Anyone have a wiring Diagram for this dryer. Any Suggestions????
rsuch
#2 Posted : Monday, January 14, 2008 12:15:54 PM(UTC)
rsuch
Is there a break in the power cord? If cord is OK, it could be the thermal fuse again, especially if the duct work is clogged with lint. This would cause overheating and blow the thermal fuse. Check and clean this all the way from the dryer to the outside vent, and don't forget the filter screen. You can easily check the thermal fuse for continuity.
