Hi - The turn table won't turn in my Sharp Microwave-Convection (model R-930) oven won't rotate. Everything else is fine. Any suggestions on what the problem is and the parts to replace?
Thank you for your help! :)
Remove the bottom panel and check for 120 VAC to the turntable motor while the control calls for heat. If the voltage reading is correct, replace the motor. If the voltage is incorrect, replace the control board. - The turntable motor Part number: AP4575305
