i
correction model no wwa5669mal -I am getting water on flood under washer could it be a hole in the tub
thanks for your help LASERDOG
On this model there is a possibility the tub has a hole in it and if it does it is time for a new one. But you need to remove the back and attempt to see where the water is coming from. The water pump will often leak and also there is a rubber boot at the bottom of the tub that will sometimes leak. Post what you find. Clothes Washer Repair Guide
Originally Posted by: applianceman ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) On this model there is a possibility the tub has a hole in it and if it does it is time for a new one. But you need to remove the back and attempt to see where the water is coming from. The water pump will often leak and also there is a rubber boot at the bottom of the tub that will sometimes leak. Post what you find. Clothes Washer Repair Guide there was a hole at the top of the tub about a inch wide and when it spin out the water came out on the floor so i took some clear all purpose silicone sealant and duck tape i put a piece of tape on the outside of the tub over the hole i then put the silicone on the inside of the tub over hole and spade it over the hole and let dry and it work
