2 Pages<12
Servicer
#11 Posted : 11 years ago
Servicer
Hello,
Sorry to bring this thread back from the dead, but I'm working on a friend's Thermador, built by KitchenAid, SxS with a freezing fill tube. I installed part number AP5330657, but have nowhere to install the wires. A later version of this unit had a plug, into which the wires will plug, but the unit I'm working on does not.
So, I have a couple questions. First, is there a plug up top that I'm missing? There is one, but the connector is different and it's not energized. The wire colors are BK-W and W-O. Second, if there is no harness, can I splice into the main L1/N that are leaving out of the power switch, assuming that the heater is always energized.
Thanks,
Kris
Jerry / APP Team
#12 Posted : 11 years ago
mattt
Hello,
This part Part number: AP5330657
is actually called for in the units' part list for the previously mentioned model number. Had you listed the model number, I could have looked it up and given you more specific information. If this part were going to be installed, it would have to be spliced into the black (L1) and white (neutral) wires for the icemaker on the cabinet side of the fusible link. I am, of course, assuming that the water pressure to the unit and the water inlet valve have been eliminated as the cause of the complaint.
Servicer
#13 Posted : 11 years ago
Servicer
Thanks, Jerry.
When I got into work this morning, I was able to look up the wire diagram (attached) and found that the 2-pin harness that's up there is the fill tube heater harness, but with a different connection.
I'm going to go back, cut the connectors and wire nut the harnesses together.
The model number is KBUDT4850A/01
Thanks again..
Kris
File Attachment(s):
KBUDT4850A01_WD.pdf (821kb) downloaded 2 time(s).
Kitchen Aid Ice Maker Problem (Refrigerator & Freezer Repair)
by morrepe 6 years ago
Kitchen Aid ice maker not working (Refrigerator & Freezer Repair)
by Rockk 8 years ago
kitchen aid ice maker (Refrigerator & Freezer Repair)
by kodiakcletus 12 years ago
Yes, another Kitchen Aid ice maker issue! (Refrigerator & Freezer Repair)
by City Tech 12 years ago
by Davy99 13 years ago
Kitchen aid ice maker - Relay, overload, or compressor (Refrigerator & Freezer Repair)
by dlstyley 14 years ago
by KWexler 14 years ago
Kitchen Aid Ice maker optics not working (Refrigerator & Freezer Repair)
by pcollier 14 years ago
Kitchen Aid Ice Maker (Refrigerator & Freezer Repair)
by drjmike 15 years ago
Kitchen Aid Ice Maker stopped working (Refrigerator & Freezer Repair)
by wocao 15 years ago
Incomplete cycle on Kitchen Aid Ice Maker (Refrigerator & Freezer Repair)
by jondska 15 years ago
Kitchen Aid ice maker freezes ice but will not dispense (Refrigerator & Freezer Repair)
by craigibc 16 years ago
Kitchen Aid Ice maker will not eject (Refrigerator & Freezer Repair)
by jwy90720 16 years ago
Kitchen aid ice maker (Refrigerator & Freezer Repair)
by irishmac777 16 years ago
by E Jim K 16 years ago
2 Pages<12
