2 Pages<12
Servicer
#11 Posted : Saturday, March 29, 2014 8:07:37 PM(UTC)
Servicer
Hello,
Sorry to bring this thread back from the dead, but I'm working on a friend's Thermador, built by KitchenAid, SxS with a freezing fill tube. I installed part number AP5330657, but have nowhere to install the wires. A later version of this unit had a plug, into which the wires will plug, but the unit I'm working on does not.
So, I have a couple questions. First, is there a plug up top that I'm missing? There is one, but the connector is different and it's not energized. The wire colors are BK-W and W-O. Second, if there is no harness, can I splice into the main L1/N that are leaving out of the power switch, assuming that the heater is always energized.
Thanks,
Kris
Jerry / APP Team
#12 Posted : Monday, March 31, 2014 5:38:29 AM(UTC)
mattt
Hello,
This part Part number: AP5330657
is actually called for in the units' part list for the previously mentioned model number. Had you listed the model number, I could have looked it up and given you more specific information. If this part were going to be installed, it would have to be spliced into the black (L1) and white (neutral) wires for the icemaker on the cabinet side of the fusible link. I am, of course, assuming that the water pressure to the unit and the water inlet valve have been eliminated as the cause of the complaint.
Servicer
#13 Posted : Monday, March 31, 2014 6:00:29 AM(UTC)
Servicer
Thanks, Jerry.
When I got into work this morning, I was able to look up the wire diagram (attached) and found that the 2-pin harness that's up there is the fill tube heater harness, but with a different connection.
I'm going to go back, cut the connectors and wire nut the harnesses together.
The model number is KBUDT4850A/01
Thanks again..
Kris
File Attachment(s):
KBUDT4850A01_WD.pdf (821kb) downloaded 2 time(s).
Kitchen Aid Ice Maker Problem (Refrigerator & Freezer Repair)
by morrepe 8/2/2019 5:56:06 AM(UTC)
Kitchen Aid ice maker not working (Refrigerator & Freezer Repair)
by Rockk 7/21/2017 9:34:37 AM(UTC)
kitchen aid ice maker (Refrigerator & Freezer Repair)
by kodiakcletus 8/5/2013 5:41:34 AM(UTC)
Yes, another Kitchen Aid ice maker issue! (Refrigerator & Freezer Repair)
by City Tech 12/14/2012 5:50:19 AM(UTC)
by Davy99 4/3/2012 3:42:51 PM(UTC)
Kitchen aid ice maker - Relay, overload, or compressor (Refrigerator & Freezer Repair)
by dlstyley 8/30/2011 7:29:14 PM(UTC)
by KWexler 5/17/2011 9:56:25 AM(UTC)
Kitchen Aid Ice maker optics not working (Refrigerator & Freezer Repair)
by pcollier 1/5/2011 9:58:46 AM(UTC)
Kitchen Aid Ice Maker (Refrigerator & Freezer Repair)
by drjmike 1/27/2010 6:17:17 PM(UTC)
Kitchen Aid Ice Maker stopped working (Refrigerator & Freezer Repair)
by wocao 10/3/2009 8:35:33 AM(UTC)
Incomplete cycle on Kitchen Aid Ice Maker (Refrigerator & Freezer Repair)
by jondska 9/19/2009 8:39:20 AM(UTC)
Kitchen Aid ice maker freezes ice but will not dispense (Refrigerator & Freezer Repair)
by craigibc 8/27/2009 8:56:34 PM(UTC)
Kitchen Aid Ice maker will not eject (Refrigerator & Freezer Repair)
by jwy90720 7/31/2009 9:59:14 AM(UTC)
Kitchen aid ice maker (Refrigerator & Freezer Repair)
by irishmac777 7/21/2009 6:00:14 PM(UTC)
by E Jim K 7/3/2009 7:26:14 AM(UTC)
2 Pages<12
