konbit
#1 Posted : Monday, January 7, 2008 7:41:34 PM(UTC)
konbit
:eek: Hi, I'm having a problem with my Maytag front loading washer, it will make some sounds but water will not come into the tub at the begining of thwe wash cycle. I tried the rinse cycle out some water came into the tub but the washer would cut off after about a 30-60 seconds:confused: .
#2 Posted : Tuesday, January 8, 2008 7:51:43 PM(UTC)
Check the water inlet valve, the water pressure switch and the main board as described in the service manual.
- The part number for the main control board is AP3672790
- The part number for the water inlet valve is AP251181
- The part number for the water pressure switch is AP4026822
- Here are the break down diagrams fro the Maytag Neptune stackable washer/dryer Model MHW2000AWW
Good luck.
