tfuertes
#1 Posted : Tuesday, February 28, 2012 4:28:57 PM(UTC)
tfuertes
My upper over won't heat up in "bake" mode. Bottom works fine and upper broiler also works fine. Are there separate ignighters for the bake and broil burners?
Simon / APP Team
#2 Posted : Tuesday, February 28, 2012 5:09:02 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely you have a bad bake igniter. Run simple test. Get to the upper bake igniter, turn the bake on and see if it glows at all. If it glows, check the amps draw - approximately 3.2 amps. Less then 3.0 amps - replace the igniter. If it doesn't glow - check the continuity. No continuity - replace the igniter.
The igniter part number Part number: AP4102012
Post the results.
