Originally Posted by: christophermurphy  I did find the test manual and checked the fill, wash/rinse, and water heating circuits. Everything checks good except the heating element. I will order a control board and a heating element. I will post the results after I install them.
Chris I have a Kitchenaid KUDI24SEAL1 I replaced the control board and still cannot get the unit to run or rinse. It will fill and drain correctly. All the lights on the touch panel operate correctly. If I rest the touch panel it seems to go through everything correctly with the lights but still will not start. Is there anyway to figure out what is causing the NO run or rinse condition? John Marron mar97034@msn.com
