racer951
#1 Posted : Monday, January 7, 2008 1:26:48 PM(UTC)
racer951
My wife went to cook a roast the other day,preheated oven 350 ,2 hours later raw roast. I turned off and back on the oven it never got hot.
Today I removed the inside bottom and heat spreader turned on the oven and it lit and heated to 350 in about 5 minutes.:confused:
Intermittant problem???
Peter
#2 Posted : Monday, January 7, 2008 5:42:34 PM(UTC)
Hi Peter,
If you see any of the following problems:
a) Oven shuts off during the Bake cycle and food is not
cooked;
b) Oven will not light, or will light, and then shut off;
c) Oven burner ignition is sporadic;
d) Oven may “lockout” after cycling the oven burner at
Bake settings;
e) Oven cools down after preheat;
then the bake burner has to be replaced.
- The part number for the bake burner assembly is AP3598752
Good luck.
Range oven problems. (Oven Repair (including Ranges and Cooktops))
by jorge osorio 1/29/2019 1:16:21 PM(UTC)
Whirpool Oven Problems (Oven Repair (including Ranges and Cooktops))
by phsffaman 2/15/2014 6:35:40 PM(UTC)
GE Profile Oven Problems (Oven Repair (including Ranges and Cooktops))
by RSF 10/16/2013 10:23:15 PM(UTC)
wall oven problems (Oven Repair (including Ranges and Cooktops))
by jethro75 8/1/2013 6:35:09 AM(UTC)
by jsn.watson1@gmail.com 5/22/2013 8:53:57 AM(UTC)
Jenn-Air Double Oven Problems (Oven Repair (including Ranges and Cooktops))
by goatguns 5/14/2013 7:38:11 PM(UTC)
Jennair Oven Problems! (Oven Repair (including Ranges and Cooktops))
by dazras 3/18/2013 7:03:17 PM(UTC)
Five Star Duel Fuel Oven Problems (Oven Repair (including Ranges and Cooktops))
by menergy 11/20/2012 4:16:12 PM(UTC)
Oven problems (Oven Repair (including Ranges and Cooktops))
by allen9258 10/5/2012 10:11:44 AM(UTC)
Jenn Air double wall oven problems (Oven Repair (including Ranges and Cooktops))
by jetdoc 9/12/2012 5:43:54 AM(UTC)
Whirlpool oven problems... (Oven Repair (including Ranges and Cooktops))
by chappy801 5/31/2012 6:42:47 PM(UTC)
Thermador oven problems (Oven Repair (including Ranges and Cooktops))
by seltzd 4/19/2012 6:13:43 AM(UTC)
by dms 2/2/2012 1:12:14 PM(UTC)
Gas oven problems (Oven Repair (including Ranges and Cooktops))
by Bumpbk 9/19/2011 8:26:32 PM(UTC)
whirlpool gold 465 oven problems (Oven Repair (including Ranges and Cooktops))
by snowfarmer 6/6/2011 2:56:02 PM(UTC)
