I have a fridgeadaire washer/dyer combo commercial electrolux with a 3/4 hsp motor. When the dryer is in operation it has a very loud and disturbing squeal. Is there a place to oil a bearing, wheel or tighten a belt? If so how do I get to the problem to rectify it? Thanks for any info!
Originally Posted by: larrymerrell I have a fridgeadaire washer/dyer combo commercial electrolux with a 3/4 hsp motor. When the dryer is in operation it has a very loud and disturbing squeal. Is there a place to oil a bearing, wheel or tighten a belt? If so how do I get to the problem to rectify it? Thanks for any info! i dont know if this will help. i have same problemi googled why my dryer squeaks an frigidaire appl guy says rear drum bearing..there was someother responsesbut he says worked on these 15years hes sure the sooner fixed the least have to replace he even tells you how to do it if need more info let me know
