windsordan
#1 Posted : Thursday, July 30, 2009 7:25:42 AM(UTC)
windsordan
Dryer will not heat on lower heat cycles. It will heat on higher heat cycles. Could it be the cycling thermostat?
sidfink43
#2 Posted : Friday, July 31, 2009 4:45:03 PM(UTC)
sidfink43
Rank:: Advanced Member
Because your cycling thermostat is a bias thermostat I think it is likely the problem. And because it is inexpensive it makes sense to change it out and see if that fixes the problem. Here is the part
Part number: AP3131939
I think you have made the correct call, let's see.
