resloan
#1 Posted : 16 years ago
resloan
The washer went out suddenly on a heavy load. I pulled off the front and the idler pulley, bearing and pin were laying separately in the bottom. Belt OK. Looking closely at the idler pulley I can see a crack in the side. From the top I can turn the agitator CCW easily. CW requires I first turn ccw to a check and then turn CW. The tub moves with the agitator in either direction. Motor works. Is this a bad tranny?
Does this sound like a reasonable repair job? Or go for a new machine.
If a new one, any recommendations? (Having a bad back, wife needs a top load. I've looked at some reviews of newer machines and have seen a lot of bad reviews, hence thinking of trying to get a used older model.)
#2 Posted : 16 years ago
What is the complete model number of the washer?
resloan
#3 Posted : 16 years ago
resloan
The plate with this info (on top of control panel) is faded out. It was made in 1993, is extra-large capacity, 3/4 hp motor. Never a problem til now.
#4 Posted : 16 years ago
Unfortunately without correct model number we are not able to find correct part numbers as well as break down diagrams. Guessing is not the way I would like to go.
Regarding a new washer I would recommend a top load machine made by Whirlpool without any electronics. Such washer, depends on capacity, can cost you between $350 to $500.
GE washer doesn't agitate or spin (Washer Repair)
by natestiles 9 years ago
GE washer doesn't agitate or spin consistently; transmission warm (Washer Repair)
by clepple 11 years ago
by czy6ltlft 15 years ago
GE Washer Doesn't Agitate or Spin!!! (Washer Repair)
by Pewterwssicc 15 years ago
Washer Doesn't Agitate Or Spin (Washer Repair)
by upvacman 16 years ago
