AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer starts then stops when drum is manually moved
Hello, I have a Maytag electric dryer. It will start and run a complete cycle (on any of the three dryer settings) and then on the next load, it will stop after 2 - 5 minutes. At first I thought it was the timer, then my wife noticed that the light wasn't coming on when it was in it's non-start mode. I noticed that when I move the drum, the light can be made to come back on, and it will run...sometimes. When it does run, it does dry the clothes. Could it be the belt and/or belt pulley?
Any ideas would be appreciated.
Thank you.
Groups: APP Team
Please specify which light comes on when you move the drum.
Sorry, the interior light comes on. There are no external lights. Thx for getting back so quickly.
Groups: APP Team
Most likely the problem is with door switch. With power off raise the top and check for continuity between white and yellow/black wires with door closed. The door switch Part number: AP4319999
Thx again 4 quick response. Now, of course, it's working just fine. I didn't have a chance to check the light.... Very strange.
Dryer Repair
