kleve
#1 Posted : Thursday, July 23, 2009 7:36:13 AM(UTC)
kleve
My Maytag top loading washer is leaking from the bottom when it hits the spin cycles, can you help me out
thank you
applianceman
#2 Posted : Thursday, July 23, 2009 7:51:19 AM(UTC)
applianceman
If it is leaking where the transmission enters the tub the tub seal is bad the page will help with that Maytag Tub Seal Replacement
If this is not where the leak is comming from post back with more info.
kleve
#3 Posted : Thursday, July 23, 2009 8:27:46 AM(UTC)
kleve
not sure, how can I tell where it is exactly leaking from if it is right side up when it is spinning, thank you so much
applianceman
#4 Posted : Thursday, July 23, 2009 10:12:21 AM(UTC)
applianceman
Remove the front so you can watch it. Two screws or clips at the bottom either hold on the front.
