my may tag washer is shaking very badly while in spin cycle do i need a herring ,how do i fix problem,the machine is level thanks pat
Originally Posted by: pat odea ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) my may tag washer is shaking very badly while in spin cycle do i need a herring ,how do i fix problem,the machine is level thanks pat Hello . Everything points to the balance ring Part number: AP4340045
sometimes these will get a hole in them and loose the filling that balances the tub, more than likely this is your problem ,I would check this, Thank you and good luck !
