Mbat4
#1 Posted : Monday, February 13, 2012 3:12:24 PM(UTC)
Mbat4
Maytag washer will fill to the proper level then stop. It will not start the cycle. I turned the dial to the spin cycle to spin and drain but that does not work as well. I purchase a lid switch and installed it but no change to the problem. What is the next step? Any advice would be helpful. :confused:
sidfink43
#2 Posted : Wednesday, February 15, 2012 11:56:26 AM(UTC)
sidfink43
That should have fixed things. Check the fuse and if it is ok then try by-passing the switch to rule it in or out.
Maytag washer will not agitate or spin (Washer Repair)
by roscoepcoltrain 4/19/2012 4:55:32 AM(UTC)
