igtaylor3@msn.com
#1 Posted : 16 years ago
igtaylor3@msn.com
:confused: My machine had a hot electic odor and stopped. Controller will not respond.
#2 Posted : 16 years ago
Check the circuit breaker for the washer and make sure there is 120 VAC at the washer outlet.
Open the control panel and check all wires and connections.
Check the lid switch.
Remove the washer cabinet. Check the motor.
Remove the pump and the motor and check how freely the transmission shaft is moving in both directions.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LSQ9549LW0 | AppliancePartsPros.com
The disassembly instructions are attached to the reply.
File Attachment(s):
How to remove the washer cabinet.doc (25kb) downloaded 12 time(s).
How to remove the pump.doc (25kb) downloaded 3 time(s).
How to replace the motor drive coupling.doc (25kb) downloaded 5 time(s).
