fireeatr
#1 Posted : 16 years ago
fireeatr
I have been searching this forum and stumbled across a couple of similiar problems. I tried undoing the dryer vent and turning it on but it still doesn't heat. The igniter glows and I have replaced both coils. I hear them click when the igniter glows bright orange but no flame. I am having problems with ohm check on the flame sensor and thermal fuse when I apply the digital MM. it seems to register a lot of different readings.
Thanks,
Deron
magician59
#2 Posted : 16 years ago
magician59
Check to make sure the gas is on. If it is, replace the radiant (flame) sensor.
fireeatr
#3 Posted : 16 years ago
fireeatr
the main gas line is definitely on.
Maytag Dryer No Heat - Burnt Wire - Causes? (Dryer Repair)
by RobH7 12 years ago
Maytag Dryer No Heat (Dryer Repair)
by bros250 13 years ago
Maytag dryer no heat (Dryer Repair)
by terryleeharvey 14 years ago
Maytag dryer NO HEAT (Dryer Repair)
by vettyfunny 15 years ago
maytag dryer no heat (Dryer Repair)
by rdnyjoh 17 years ago
