I jave RCA Micro wave, RMW1112 model. I had a pronlem with it. it used to shutdown occasionally for short peiod of time, if i am heating up something. All the lights and power will be gone. If i let it cooldown for few minutes it will be back and run ok. Yesterday, it went dead and did not came back up. Any suggetion if i need to check something up or is just gone.Your help will be appreciated. Thanks:mad:
]I have RCA Micro wave, RMW1112 model. It was working fine and heated some vegitables but half an hour later it just stopped working. Everything seems to be operational except it won't heat. Is there a reset for this thing? It's only eight months old and will probably cost us a fortune to get it fixed as nobody stands behind there products anymore. So, am I hooped, out of luck and so on?
