deli63
#1 Posted : Wednesday, February 8, 2012 5:10:25 PM(UTC)
deli63
I have replaced ice maker and water inlet valve on back of fridge still no water to icemaker manually fill and jump t and h and maker rotates dumping ice remove jumper and rotates around then quits any ideas please
plmcelroy
#2 Posted : Wednesday, February 8, 2012 5:37:06 PM(UTC)
plmcelroy
check to be sure water is on then defrost feed tube with hair dryer so there is no ice clog. Feed tube is in rear of ice maker. Good luck
plmcelroy
#3 Posted : Wednesday, February 8, 2012 5:45:25 PM(UTC)
plmcelroy
disconnect water line feeding ice machine from water valve on back of fridge. Rotate icemaker through cycle line should dispense water. If no water, the problem is valve or actuating switch in ice machine.
deli63
#4 Posted : Wednesday, February 8, 2012 8:06:30 PM(UTC)
deli63
thank you for tip i did have freezer off and cleaned today which should have thawed any ice in line i will check the line though at rear of ice maker and the connectors at valve thanks again
Guest (5)
Whirlpool Icemaker Not Filling With Water (Refrigerator & Freezer Repair)
by jgibby65 1/28/2013 2:13:27 PM(UTC)
Icemaker not filling with water (Refrigerator & Freezer Repair)
by wester2009 5/26/2009 10:51:51 AM(UTC)
by grtspcs 4/21/2009 9:24:10 AM(UTC)
icemaker not filling with water (Refrigerator & Freezer Repair)
by joni08 1/27/2008 1:47:16 PM(UTC)
