Ice accumulates under the bottom panel of the freezer. This is causing water to drip down into the fridge.
It was defrosted and it happened again in 2 weeks. The drain hole is not clogged. (except for the ice) The freezer is not set too cold.
I wish the solution was that easy.:(
I would imagine that this one is going to co$t me. Any ideas? Thanks.
