edbrown2222
#1 Posted : Saturday, February 4, 2012 6:40:54 PM(UTC)
edbrown2222
Our Maytag washer Model # LAT8826AAE will fill and agitate fine, but will not drain/spin then advance to rinse cycle. The timer will advance to the end of the cycle but the tub is left sitting full of water with fabric softener still in the dispenser on top of the agitator. If I then move the dial back around between the wash/rinse cycle and find the "sweet spot" the tub will drain/spin/rinse/drain/spin then proceed completely to the end of the cycle. However, it is very difficult to find the "sweet spot". Sometimes we also just have to pull out on the time knob and move it back and forth then the tub will begin draining then spin and proceed to the rinse cycle (almost like there is some type of short). I purchased a new timer from this site (PN 22001694) and installed it. However, the new timer would not advance at all. The tub filled and agitated fine, but the new timer would not even move, just stayed on "wash" and continued agitating. I had to manually move the new timer one click at a time to get the machine to drain/spin/rinse/spin. So I called customer service and told them the new timer was bad so they sent me another one. I installed it today and same thing. The 2nd new timer also will not advance past wash. It fills then just agitates forever unless I manually advance the timer one click at a time through the various cycles. I checked the continuity on the lid switch and it is ok. I did re-install the original timer and it is doing the same thing. The timer still advances to the end of the cycle, but the drum fills & agitates, but does not drain/spin/rinse/spin. It is still sitting full of water once the timer is done, then I have to manually find the "sweet spot" again. I doubt if I received two bad timers; there are two different timers listed on the site for this model, could one of them be incorrect and I just happened to order the wrong one? Or could this be another issue? Sorry for the long-winded post, but I am confused. :confused:
sidfink43
#2 Posted : Monday, February 6, 2012 5:17:54 PM(UTC)
sidfink43
Well I am confused also, since I think what you did should have fixed things.
I am thinking its the motor switch, since the motor is working. Try replacing it
Part number: AP4023837
edbrown2222
#3 Posted : Wednesday, February 8, 2012 3:12:37 PM(UTC)
edbrown2222
I called customer service and asked if it was possible that I had ordered the incorrect timer since there are two different timers listed for model #LAT8826AAE. Turns out I did. I orginally ordered P/N AP4026298; however, based on the serial # of my washing machine I needed timer P/N AP4027817. Lesson learned...if there are two parts listed call first and confirm which one is needed based on the serial # of the machine. Fortunately APP.com will take the first timer back and give a full refund.
sidfink43 - thank you very much for the reply. The motor switch was next on my list to try, so at least I feel better knowing I was on the same path as an expert.
I am very pleased. I was able to repair a washing machine my wife loves for less than $150 instead of buying a new high efficiency maching for $700-$1,000 that my wife is leary of. Thank you Appliance Parts Pros.com! :)
sidfink43
#4 Posted : Wednesday, February 8, 2012 4:53:53 PM(UTC)
sidfink43
Well great, glad you got it fixed. APP should have known to ask you for a serial number, particularly on Maytag which is always doing this change parts number but leave model number the same.
Good luck, and thanks for getting back to us.
