Start up microwave, it goes for about 10 seconds, you hear a light sounding click from the inside & microwave and it goes off. Message comes on to reset time, & date. Reset the time and date and the start it up again, same thing happen's again, keep's going off.
Very likely the problem is a bad magnetron due to electromagnetic waves leakage. The solution is to replace the magnetron. You can use the OEM part or the aftermarket part, which is exactly the same part, but cost much less - The OEM magnetron Part number: AP2025937
