I bought a new control module for myh SHU4306 and it is just slightly different from the old module. On the far right of my old module (when looking into the open moduel) there is a plug that is attached to the circuit board. It was attached to the circuit board at an area labled 274' This plug has a small red wire that jumps two of the connections. No wires from the dishwasher were plugged into this plug. This plug is easily removed.
The new control module has a place for this plug to fit, but does not come with one. Should this new module be complete as is or should I move the "jumped plug" to the new module? TIA
The jumper plug has to be moved from the old control to the new one.
Originally Posted by: Gene The jumper plug has to be moved from the old control to the new one.
Gene. Thank you...Thank you...Thank you. The new module is in and it appears to be functioning fine. Happy New Year! :)
I'm glad you were able to fix it.
Happy New year to you and your family as well!
