aspryj
#1 Posted : Wednesday, January 2, 2008 5:21:14 AM(UTC)
aspryj
Rank:: Member
My washer is stoping on the regular cycle. It works fine on all others? What is my problem part? Thanks
#2 Posted : Wednesday, January 2, 2008 3:09:39 PM(UTC)
At what point exactly it stops?
Post as much information as possible.
aspryj
#3 Posted : Thursday, January 3, 2008 3:23:05 AM(UTC)
aspryj
Rank:: Member
The washer will not stop everytime but only on the regular cycle it may stop when the water fills up to rinse before spinning out. All other cycles have no issues. This is a Maytag Washer model LAT9606AAE serial #222915165w. Thanks for any help you can provide !!
#4 Posted : Thursday, January 3, 2008 2:14:50 PM(UTC)
If it stops before water fills up - most likely the problem is the water inlet valve.
If it stops after water filled up, then the problem is the timer.
- The part number for the water valve is AP251108
- The part number for the timer is AP250938
- Here are the break down diagrams for the Maytag washer Model LAT9606AAE
Good luck.
