jim
jim6565
#1 Posted : Tuesday, January 1, 2008 9:15:33 PM(UTC)
jim6565
this dryer wont heat its actually a RCA brand but I'm told that GE makes them. i replaced the element but no luck, checked the outlet and it has 220. there is only 120 when i checked the voltage at the heating element itself what could be the cause thanks for any help you can give
richappy
#2 Posted : Wednesday, January 2, 2008 2:38:00 AM(UTC)
richappy
With power on, check between thermal fuse, overload thermostat terminals. Any voltage reading indicates a bad control.
jim6565
#3 Posted : Wednesday, January 2, 2008 12:04:30 PM(UTC)
jim6565
i dont see a thermal fuse where would it be
jim6565
#4 Posted : Wednesday, January 2, 2008 12:05:57 PM(UTC)
jim6565
is there someplace i can find a parts list or wiring diagram for this dryer
richappy
#5 Posted : Wednesday, January 2, 2008 1:01:17 PM(UTC)
richappy
Your thermal fuse for the heater is near the top of the heater housing.
jim6565
#6 Posted : Wednesday, January 2, 2008 9:17:00 PM(UTC)
jim6565
when i checked what the schematics called a safety its right next to the thermostat on the heater housing, if i touch the 2 terminals on the safety theres no voltage same with the thermostat, but if i touch a terminal on each of them theres voltage.
richappy
#7 Posted : Thursday, January 3, 2008 1:04:46 AM(UTC)
richappy
Sounds like you have a blown thermal fuse on the upper section of the heater housing. New one comes as a kit with a new overload thermostat which must be replaced at the same time.
Before replacing parts, please clean your ducting, clog there caused your fuse to blow
jim6565
#8 Posted : Saturday, January 5, 2008 11:55:40 AM(UTC)
jim6565
that didn't do it there is a resistor in between the heat selector and the timer if i take it out and hook the 2 wires together it heats but i still don't have 220 at the heaters is the resistor bad.
richappy
#9 Posted : Sunday, January 6, 2008 1:17:39 AM(UTC)
richappy
If you short out the resistor, you will blow out your timer motor. You might have a bad timer. I usually take them apart to check. Just measure across the heavy gauge wires going to it, if open, it's bad.
Guest (5)
Jenn-Air JIM158XBRS2 freestanding ice maker HELP! (Refrigerator & Freezer Repair)
by DaveRicciuti 6/11/2019 12:18:15 PM(UTC)
jim123 (Washer Repair)
by jim 123 3/26/2015 12:59:17 PM(UTC)
Jimmy T. (Dryer Repair)
by Jimmy T. 7/27/2013 5:41:06 PM(UTC)
Jimkeyes (Refrigerator & Freezer Repair)
by JimKeyes 10/3/2012 1:06:39 PM(UTC)
jim (Refrigerator & Freezer Repair)
by jim baird 7/12/2012 11:40:58 AM(UTC)
Jim (Washer Repair)
by Jimm1 4/17/2012 6:04:21 PM(UTC)
Jim (Dryer Repair)
by jetoan123 3/16/2012 6:17:59 PM(UTC)
jim b56 (Oven Repair (including Ranges and Cooktops))
by jim b56 2/12/2012 8:51:37 AM(UTC)
jim Colucy (Washer Repair)
by Jim Colucy 9/4/2010 9:23:51 AM(UTC)
Jim E (Refrigerator & Freezer Repair)
by jim eckart 8/26/2010 11:28:36 AM(UTC)
by jim eckart 8/19/2010 4:59:14 PM(UTC)
by jim crane 8/16/2010 3:59:48 PM(UTC)
Jim Kennedy (Oven Repair (including Ranges and Cooktops))
by Jim Kennedy 1/6/2010 11:44:01 AM(UTC)
by Jim Kennedy 1/6/2010 11:41:53 AM(UTC)
jimmyb (Dryer Repair)
by jbradford 11/24/2009 6:07:56 PM(UTC)
