Have an F# code. Oven sensor open. Checked with meter and get 1091 ohms at the sensor plug. Tried at the plug going into the control panel and get the same. Is the sensor really "open" at 1091 or is there a fault in the control board?
If it reads 1091 Ohms at the control board plug then the problem is a bad control board. - The control board Part number: AP2150432
