aracadia
#1 Posted : Sunday, July 12, 2009 2:09:28 PM(UTC)
aracadia
Plunger goes down but will not come up unless the switch is turned again.
I called KA and they said it was the limit switch ( top right side ) which I purchased and replaced. Same problem exists after the new switch is installed. I'd appreciate your advice on what I can do next. Thanks.................
#2 Posted : Monday, July 13, 2009 1:20:11 PM(UTC)
Most likely the problem is a bad "Solid-Normal" option switch. If you need the correct part number then verify and repost the model number of the trash compactor. The model number you posted does not come up.
aracadia
#3 Posted : Monday, July 13, 2009 8:17:27 PM(UTC)
aracadia
the model number us KUCC151JSS0
Is the solid-normal switch in the same area as the limit switch?
thanks!
#4 Posted : Tuesday, July 14, 2009 4:31:05 PM(UTC)
It is the options push-button switch on the control panel. Before proceeding with any repairs make sure you choose the "Normal-Unlocked" option. You can learn how to operate your trash compactor from the Owners manual.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KUCC151JSS0 | AppliancePartsPros.com
