croberts
#1 Posted : Tuesday, January 1, 2008 10:05:24 AM(UTC)
croberts
My Kenmore dryer will stop in mid-cycle and then will restart after a few minutes. It does this sporadically and the clothes are getting dry. I this a problem with a thermostat?
richappy
#2 Posted : Tuesday, January 1, 2008 4:59:24 PM(UTC)
richappy
If the motor makes a bad noise when starting, it's got bad bearings and needs to be replaced
croberts
#3 Posted : Thursday, January 3, 2008 4:50:42 PM(UTC)
croberts
Thanks for your reply. No, the motor does not make any strange noises and I have thouroughly cleaned the lint filter and duct. Any other ideas?
richappy
#4 Posted : Friday, January 4, 2008 12:21:15 AM(UTC)
richappy
Check your timer for burnt contacts, symptom would be gaps in the timer when you turn it or wiggle the timer knob. If it takes a few minutes till you can get the motor running=bad motor shutting down on it's thermal overload. You can confirm this by bench testing the motor with 115 volts to pins 4&5
