I need to replace the power cord in my Samsung refrigerator. I took off theback of the refrigerator and traced the cord to a small white plastic boxlocated on the lower right corner of the refrigerator, behind the water line. Itried to open this box, however after removing the one screw I could not getthe box to open. I didn't want to force it open. First, how do I open thisbox-I tried to push down on the tab and it doesn't seem like it wanted to move.Second, once I get inside the box, is it a simple hook-up (white to white/blackto black/green to ground) or is it more detailed? Thanks for thehelp!!
the box does just come apart but it is HARD to open,the tabs do help it come apart,the power cord plugs into a board inside the box
Thank you very much Appliance Pro for your response.
