SYMPTOM: Discovered side-by-side freezer water on floor & food thawed. ACTION: Raised Freezer Temp setting to maximum and freezer no longer thaws. INVESTIGATION: Set Freezer Temp back to nominal and added a remote thermometer to obtain resulting operating temp range. At normal setting, freezer temp ranges between -15F<-->20F; Refrigerator ranges looks OK at between 36F<-->38F.
QUESTION: What might cause the large Freezer variation. I expect maybe +/- 5F variation.
Suspect if you didn't adjust the cold control it would have stayed inoperative. When it failed, what was running/not running? If not running, the defrost control was jammed, or the cold control stuck. I would spray both the defrost timer and cold control with a non-residue spray and turn/rotate to clear any contamination.
Originally Posted by: richappy ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Suspect if you didn't adjust the cold control it would have stayed inoperative. When it failed, what was running/not running? If not running, the defrost control was jammed, or the cold control stuck. I would spray both the defrost timer and cold control with a non-residue spray and turn/rotate to clear any contamination. I'll give your suggestions a try. Hopefully I can locate the controls you mentioned. THANKS! As for the exact symptoms when the failure occured, I was on vacation at the time and my son was the one who turned up the Freezer temp setting. Therefore I can't say if the refer was running or not running :-(
