Used the self cleaning mode, and while cleaning the inner glass panel shattered, and the display showed a fault code and also became very dim. The lower oven still works but display goes from dim to dimmer. Will installing a oven display repair kit # ap4929088 solve this problem? Do I need any other parts to fix glass other than the glass panel ?
Originally Posted by: twaken ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Used the self cleaning mode, and while cleaning the inner glass panel shattered, and the display showed a fault code and also became very dim. The lower oven still works but display goes from dim to dimmer. Will installing a oven display repair kit # ap4929088 solve this problem? Do I need any other parts to fix glass other than the glass panel ? Help anyone ?
