my dryer have no heat. i did check heating continuaty and its ok.Please help.:confused:
Originally Posted by: ddnguyen06 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) my dryer have no heat. i did check heating continuaty and its ok.please help.:confused: check and make sure you have 240 volts to the dryer where the cord mounts up to the terminal block. if you have it there, pull the 2 wires off the thermal fuse mounted to the element assembly, and see if you have continuity. tom
