burner control issue (electric): all burners run at 100% when set to any position; two of the control knobs when put to "on" position turn both burners on at 100%. This is equivalent to cooking over an open fire...LOL! Any input is greatly appreciated.
also of note: i have swapped cartridges (new) with same results as described above.
after a little more reading this sounds like what i am needing: Top burner infinite switch with a double flat shaft and screw mounting. Part Number: AP4088188How do i determine if i need to replace all swiches or how do i identify the faulty part(s)?
