growthstock
#1 Posted : Sunday, January 1, 2012 6:29:03 AM(UTC)
growthstock
After our cooktop was cleaned, the ignition spark continuously sparks about 1-2 times per second. This happens whether or not there is a flame present on any of the burners. I looked through this forum and found out that I should check the switch continuity for each burner, but am having trouble figuring out how to get to the wiring harness. I found the mechanical diagram for my cooktop here - Replacement parts for General Electric JGP975SEK2SS Gas range | AppliancePartsPros.com
It looks to me like I should remove all of the screws labeled "122", along with the knobs, burners and grates, in order to lift up the cooktop to get to the wiring harness. Just looking for confirmation from somebody more knowledgable than me before I start doing anything (and making my problems worse!)
